installed new tps sensor and now idles high
Old May 22, 2011 | 10:22 AM
cjy01's Avatar
Default installed new tps sensor and now idles high
i just installed a new tps sensor and now it revs high almost at 2500 and its showing a engine code #7 and 41 please help. Its a 1994 honda civic vtec
Old May 22, 2011 | 12:56 PM
Make sure the throttle plate closes fully when no one is pressing the gas pedal. Check sensor calibration: turn key on but don't start, connect voltmeter from center wire of sensor to ground with the sensor still plugged in. The voltage should be 0.4 volts. If not, loosen sensor screws and rotate to get 0.4 volts. This is after making sure the throttle plate closes fully. Also any air leaks between the throttle body and manifold will cause it to idle high.
Flow Master
Dec 31, 2023 02:56 AM
honvic
Aug 30, 2011 07:30 AM
ian125
May 4, 2011 04:54 PM
SPACEGUY18
Nov 20, 2009 02:01 PM
warnergen
29
Jul 6, 2009 09:41 AM
