installing a tachometer in a 90 civic
Old Jul 20, 2009 | 10:13 PM
andrewb648's Avatar
Default installing a tachometer in a 90 civic
i believe the wire for the tach that im looking for is the bluish greenish wire right on the distributor. not 100% on that though i got all the other wires hooked up fine any help with this would be greatly appreciated!
Old Jul 20, 2009 | 10:16 PM
The signal for the tach gauge comes on a blue wire from the coil in the distributor.
Old Jul 20, 2009 | 10:32 PM
The wire is already inside the car, behind the cluster. Tap into it there, it is much easier.
Old Jul 22, 2009 | 05:36 AM
neo1piv14's Avatar
The general wisdom seems to be: just go to a you-pull-it, find an LX, EX, or SI from your generation, and swap out the cluster with that. Looks a ton cleaner that way as opposed to bolting a tach onto your dash.
1995CivicEXBMF
Oct 14, 2009 11:38 PM
nik005
Jan 4, 2008 08:36 PM
Darkpbstar
Sep 27, 2007 01:04 PM
alternative_energy
Mar 2, 2007 01:39 AM
ShÖgun
Aug 29, 2004 04:36 PM
