Installing timing belt?
Old Mar 6, 2009 | 05:28 PM
jpnolan's Avatar
Default Installing timing belt?
So today I went to put on my new timing belt and I am having the worlds worst luck. There has got to be some mfing secret trick to it. Can someone please help! RonJ <3 no homo.
yes..... the tensioner is all the way loosened. But I still can't seem to get it on and the shop manual just says the order it doesn't say how to get it on. please help!
Old Mar 6, 2009 | 05:32 PM
jpnolan's Avatar
And ya I searched but every single diy say put on the timing belt.... mine is nowhere near sliding on and yes its the correct timing belt qq.
Old Mar 6, 2009 | 07:01 PM
What year Civic and what engine?
What have you tried so far?
And what does this mean: RonJ <3 no homo.
Old Mar 6, 2009 | 09:09 PM
jpnolan's Avatar
B18a
So the one way I did get it on but the timing got fed in the process was putting everthing but the crank on and turning it and pushing like one tooth that i could get onto the crank and it slowly would get on but it didn't like that and the timing got messed up.
Because I knew you would be one of the best people to ask.
Old Mar 7, 2009 | 03:56 AM
Hey Trustdestruction, are you out there? Do you happen to have the service manual for the B18a engine. If so, can you post the diagram/page in the manual that describes the timing belt installation. Maybe there's a detail in the manual that will help. Is the B18a a DOHC engine?
Jpnolan, in the meantime, are you able to post a clear photograph showing the cam gear(s), crank gear, and tensioner of your B18a engine all in one frame. The picture might help generate some ideas.
Old Mar 7, 2009 | 06:25 AM
Do not force a timing belt on, you're likely to damage the fibers in the belt and weaken it. They're only designed to take stress in the normal running direction and any twisting or "crimping" is very bad. At this point you might consider buying a new belt and not using the one that is potentially damaged.
You could try removing the tensioner spring and bolt so it moves completely out of the way, put the belt in place then reinstall the tensioner.
Old Mar 7, 2009 | 06:28 AM
ef9101's Avatar
the best way to put it on is the get first piston all the way up n on your cams there should be a mark that matchs with the timing belt covers bolted on the engine ill try n find some example pixs so it makes my sloppy talk more understandable
Old Mar 7, 2009 | 12:31 PM
jpnolan's Avatar
Ok guys maybe some people don't understand. Everything is set correctly. The tensioner is all the way loosened. I have the service manual. All b series are DOHC.
Old Mar 7, 2009 | 01:21 PM
Hailchristian's Avatar
you sure you got the right cam gears when you ordered them? Right crank gear? I would double check those things. On my DOHC zc it had the wrong crank gear making it super hard to get the timing belt on. It also made the car very hard to start
Old Mar 7, 2009 | 02:48 PM
Yes the crank gear needs to have exactly half as many teeth as a cam gear, or you're going to be in a world of hurt.
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
marcpasek
Oct 16, 2010 09:49 PM
pippo
Jan 26, 2010 02:40 PM
thakid
Jan 30, 2006 08:29 PM
