intermittent overheating problem
Old Sep 6, 2006 | 08:59 PM
binrocha's Avatar
Default intermittent overheating problem
'94 civic intermittent overheating problem. replaced: timing belt, water pump, t-stat, radiator, bled coolant, checked rad fan-ok, no coolant in oil, no oil in coolant, no white smoke in exhaust. the only thing i noticed, when i started the car cold, the rad overflow tube is emitting a slight mist, when submerge in the overflow reservoir, it gives the impression of boiling coolant???any ideas, anyone? - thanks
Old Sep 6, 2006 | 10:31 PM
fglaustin's Avatar
Default RE: intermittent overheating problem
as cheap as it is (compared to some you did )
i would replace the radiator cap.
are you losing any coolant?
GregM
Mar 29, 2013 01:35 PM
paintman17
Sep 19, 2006 09:14 PM
trebor_2005
May 19, 2006 01:40 AM
Expando1
Aug 12, 2005 08:34 PM
Expando1
Sep 20, 2004 11:41 AM
