knock sensor?
Old Jan 9, 2008 | 11:42 PM
reconstyle's Avatar
Default knock sensor?
So I went to swap out my PCV valve and I found this. This is on a d16y7 with the air cleaner and housing removed, right above the oil filter.
This is a connector I found that looks like it's what broke off from whatever this is...
Is this a knock sensor? My haynes manual says the y7 doesn't have one. I don't think this can be THAT important because it's not throwing any CEL's....
Old Jan 10, 2008 | 01:01 AM
reconstyle's Avatar
Default RE: knock sensor?
Ok, looks like this is the oil pressure switch. I guess I'll replace it next time I change the oil, it's only 8 bucks for a new one...
Old Jan 10, 2008 | 06:32 AM
That is indeed the oil pressure switch. You don't need to drain the oil to change it, can be done at any time.
Old Jan 10, 2008 | 09:42 AM
reconstyle's Avatar
Would it be safe to use one from advance auto parts? Or should I just go to the dealer?
Old Jan 10, 2008 | 10:10 AM
Firehawk989's Avatar
I would just get one from the dealer. Honda tends to be pretty reasonable for most part prices, and you'll have peace of mind knowing its a quality part.
Old Jan 10, 2008 | 11:33 AM
reconstyle's Avatar
It's the same price from honda, so I'll just get it from them. Thanks!
1998civicexauto
Jul 12, 2022 06:05 AM
drbyers
Oct 25, 2006 10:23 AM
drbyers
Apr 25, 2006 03:58 PM
justin
Aug 16, 2005 11:26 PM
Gvaski
Apr 3, 2005 10:07 PM
