light weight flywheel and stage 2 clutch?
Old Sep 13, 2006 | 08:56 PM
red95ex's Avatar
Default light weight flywheel and stage 2 clutch?
Is upgrading your flywheel and clutch a good place to start modifying? What are some reliable brands?
Old Sep 13, 2006 | 09:21 PM
Chimera02EX's Avatar
Default RE: light weight flywheel and stage 2 clutch?
No, IMO clutch and flywheel should come after you have enough mods/hp/tq to warrent upgrading them. Concensus here would be I/H/E, allowing the engine to breathe better.
Old Sep 17, 2006 | 09:34 PM
red95ex's Avatar
ok thank you i plan on doing all of that around the same time anyways but im pretty sure i need a new clutch so i wasn sure if i should jus start there.
Old Sep 18, 2006 | 12:16 AM
WhtRice's Avatar
Member
ORIGINAL: red95ex
Unless your stock clutch is blown and you cant stand the idea of putting another stock one in if you're gonna be down there putting an aftermarket one in a month anyways, not a great place to start but if you're down there anyways go ahead, other than that always start with your engine breathing Headers/Catback/Coldair intake
Old Sep 18, 2006 | 12:23 PM
fglaustin's Avatar
i cant think of clutches as far as giving HP gain.
Old Sep 18, 2006 | 09:35 PM
sacicons's Avatar
if you have to replace it anyway, absolutely get a stage1 and a flywheel. I prefer Exedy and ACT. But I lean more toward Exedy except they dont offer a flywheel for the sohcs. but you can mix an exedy clutch kit with an act FW.
Old Sep 19, 2006 | 09:33 PM
red95ex's Avatar
ok..im gonna do the stage one and flywheel bc i cant speed shift w/o grinding and i was told it was the clutch bc in my saturn i can shift even faster w/o grindage.
rocksbite
Jul 22, 2008 03:02 AM
DickG.
May 23, 2008 02:44 PM
CivicNooby00
Mar 21, 2007 02:42 PM
mill$civic
Sep 27, 2005 01:06 PM
the_reptilian
Sep 29, 2004 10:53 AM
