limp mode
Old Jun 23, 2010 | 01:02 PM
90civhatchb18a1's Avatar
Default limp mode
I have a rebuilt b18a1 in my 90 civic hatch. before rebuilt ran fine no limp mode had a head gasket leak. after being rebuilt car now is in limp mode. running a pr4 ecu stock pistons and rods. any help will be appreciated
Old Jun 23, 2010 | 03:53 PM
CEL codes?
Old Jun 23, 2010 | 05:03 PM
cel 4. crank angle sensor. but replaced dizzy twice.
Old Jun 23, 2010 | 05:07 PM
This is the reason for limp mode. Use a multimeter to check the two crank sensor wires for an open or short. Also inspect the corresponding wire terminals in the distributor connector.
Old Jun 23, 2010 | 05:13 PM
i checked for resistance and continuity it all checked out perfect
Old Jun 23, 2010 | 05:16 PM
Did you check for continuity to body ground (=short)?
Old Jun 23, 2010 | 05:17 PM
all grounds were good. did it when motor was rebulit
Old Jun 23, 2010 | 05:22 PM
You are not understanding the procedure to check for an electrical short. Test for continuity to body ground from each end of the crank sensor wires.
Old Jun 23, 2010 | 05:23 PM
k
i will have 2 check that out tomorrow it getting dark here in ohio ill post it on tomorrow
Old Jun 24, 2010 | 07:05 AM
Unplug the ECU and check sensor resistance and ground faults by measuring at the ECU plug. There should be infinite resistance from either sensor wire to any other wire in the plug, including ground. This verifies that the wiring harness and plugs are OK too.
Also make sure you have the plastic insulator plate installed in the distributor under the rotor. Leaving it out will allow sparks to jump down to the sensors and bad things will happen.
Decembermouse
Oct 18, 2010 12:46 PM
frankenstein616
Mar 22, 2010 04:49 PM
shiftbyear
Jan 7, 2010 10:24 AM
civic_turbo
May 2, 2008 07:08 AM
civic_turbo
Mar 29, 2008 08:24 AM
