A Little boggy
Old Feb 29, 2012 | 07:18 PM
Aaron Beausoleil's Avatar
Default A Little boggy
I have a 95 civic and its been a little boggy lately. I checked the fpr its fine, I cleaned the Idle air control valve with WD-40 because I didn't have any carb cleaner and it already made it idle better but it still has a slight bog in it. Any suggestions? It clears up at higher rpms it just bogs at the lower ones a little bit. Any ideas would be great, thanks!
-New civic owner
Old Feb 29, 2012 | 09:07 PM
Turtlegrip's Avatar
i have had a similar issue for a while now, at very low rpm, like when coming to a stop.
after cleaning the IACV (i put in a CAI at the same time) it has gotten a lot better, i would consider replacing the fuel filter, then moving on to possible spark or timing being off.
Although it would be weird, i still think mine might have to do with the electrical system some how. I have noticed i do not have the problem if i keep headlights on, or at least i havent noticed the issue with lights on. i need to figure out the ELD unit thingy haha, anyway off topic.
I would try the fuel filter then get timing checked if you still have an issue. Im gonna go get my timing redone soon since mine is under warranty from getting timing belt done recently. Ill let you know if that helps my issue, and ill check to see if anything worked for you.
Street Sniper
May 23, 2005 08:45 AM
Riceburner_SI
Apr 1, 2005 11:45 AM
IVO_CIVIC
Feb 10, 2005 08:28 AM
JohnHenry
Jan 26, 2005 02:40 AM
green98lxsedan
May 22, 2004 09:32 PM
