Location of starter relay in '05 civic
Old Nov 18, 2011 | 01:09 PM
Murph's Avatar
Default Location of starter relay in '05 civic
I have a 2005 civic LX. I replaced the starter thinking that was my problem with the car not starting. That worked for about 24 hours. Now, again the car is not turning over at all and the battery is fine. I think I do hear the fuel pump kick on when I turn the key.
I think it may be the starter relay but have no idea where it is. It is not listed in the fuse/relay box under the hood. I'd appreciate it if anyone thinks it could be the starter relay and if so, where it is located.
Old Nov 18, 2011 | 06:26 PM
anibis's Avatar
Is the green key light under the fuel/temp gauges coming on at all when the car won't start? It should come on for a few seconds when you try to start and blink 3 times when you remove the key.
Old Nov 18, 2011 | 08:19 PM
You should jump the starter to make sure the starter is OK and able to get power from the battery. Put transmission in neutral (or park if automatic), set parking brake, leave key off. Go under the hood and unplug the small wire on the starter. Connect a test wire from the small terminal on the starter to battery (+). The engine should crank.
Assuming that test passes, on manual Civics the switch on the clutch pedal is a common cause of not cranking.
Old Nov 19, 2011 | 04:33 AM
Murph's Avatar
Yes, green key light comes on and then blinks as you mentioned. What can I eliminate off the list of potential problems by that working properly?
Old Nov 19, 2011 | 01:42 PM
anibis's Avatar
Yep, the immobilizer is a common problem to have in 7th gen's that's why I asked. I would try what mk378 said next. Do you have a 5 speed or auto?
jenom
Nov 17, 2013 07:32 AM
ktorres1120
Sep 4, 2013 08:07 PM
tooquick
Jun 3, 2012 07:00 PM
MXandSXracer21
Jul 11, 2009 02:22 PM
jelloman
Jun 23, 2009 09:54 AM
