lock washers?
To make a long story short, I was changing the midway gasket between the 4-2 pipes in my header, and found out one nut has come off and is gone while driving, and one of the other 3 was loose almost all the way down the thread. Should I use lock washers?
I made a replacement gasket with expensive material. I think the reason is either because of the anti-seize I used too much, or the gasket shrunk so much that there was significant space between the nuts and the bolts. Cause I tightened the crap out of them.
Check www.fastenal.com for locknuts that can withstand heat. You DO NOT want to use nylocks or starnuts, but Fastenal has various other locknuts that should work well.
thakid
Dec 14, 2011 01:48 PM
trustdestruction
Oct 19, 2008 07:19 PM
snosurfa7
Apr 25, 2007 03:41 PM
