Loud Knocking Noise In Timing Belt Area
Old Oct 8, 2005 | 08:55 AM
nardva's Avatar
Default Loud Knocking Noise In Timing Belt Area
I have a 95 Honda Civic LX.
All of a sudden my car started making a loud knocking noise this morning. I thought it might have been coming from the engine block, but after listening a little bit harder, the sound appears to be coming from the timing belt area under the plastic cover. I might be wrong. Any suggestions on what it might be?
Old Oct 8, 2005 | 09:04 AM
Pete's Avatar
Default RE: Loud Knocking Noise In Timing Belt Area
take off the timing belt cover and give it a look-see
Old Oct 8, 2005 | 09:40 AM
nardva's Avatar
Just to add some more info. I just reved the engine up to see what would happen. As the car idled back down it started stalling a little bit. Then I started hearing squeaking and clanking noises over in the timing belt area as if gears were about fall apart. I'll see if I can remove the timing belt cover if it's not difficult. I don't know anything about working on cars. The only thing I ever did was change a flat. Right now I'm just looking to get an idea of what the problem is so I can start weighing my options on getting it fixed.
Old Oct 8, 2005 | 11:17 AM
seandala's Avatar
it sounds like your belt is loose and if it slips it could change your timing which would explain the stalling, you can use the old screwdriver trick (put the plastic on your ear the metal on the cover) and try to locate the exact problem, but a belt is not quite as easy as changing a tire but with a proper manual infront of you it should be a possible project. i would go get a chilton manual and read over the timing belt and if you think you can do it do it, the manual would also have inspection procedure in it to make sure thats the problem
Old Oct 8, 2005 | 12:58 PM
Kappa22's Avatar
Well, if the timing belt was loose enough for things to be rattling around, it probably would have fallen off by now. It sounds more like onr or more of the bolts that holds one of the pulleys on it loose, and the metal trim plates behind them could be rattling around.
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
pippo
Jan 26, 2010 02:40 PM
islandtuner
May 4, 2009 08:54 AM
TrAvMaNFTW
Feb 19, 2006 12:19 PM
