Low Compression ? Help~!
Old Jul 22, 2010 | 08:42 PM
  #21
JayVee's Avatar
If one, or more, cylinders read low, squirt approximately one (1) tablespoon of engine oil on top of the pistons in the low reading cylinders. Repeat compression pressure check on these cylinders.
1. If compression improves considerably, the piston rings are at fault.
2. If compression does not improve, valves are sticking or seating poorly.
I believe i'm stuck with one of these two problems. how does a port&polish come into my picture though?
Old Jul 22, 2010 | 09:40 PM
  #22
well do the test to find out. a port n polish is for if the valve isnt getting a good seal the machine shop grinds it and polishes the port to make a sure seal.
deffinitly do the test i posted then post results. if not piston rings then valve and a valve adj could (slight) possibility fix your prob.
Old Jul 22, 2010 | 09:44 PM
  #23
^I think you mean a valve job... port and polish is for airflow
Old Jul 22, 2010 | 10:52 PM
  #24
yea thanks stu lol im playin gears of war2 and typing on here.
Old Jul 23, 2010 | 02:23 AM
  #25
JayVee's Avatar
I got confused with the whole % part, and this is something I can do at home; myself?
Old Jul 23, 2010 | 02:31 AM
  #26
look at it again i edited it and explained it better for ya. if you can do a pressure test than yes you can do it at home , its not real hard to do
Old Jul 23, 2010 | 10:50 AM
  #27
JayVee's Avatar
The indicated compression pressures are considered normal if the lowest reading cylinder is within 75% of the highest.
Seventy-five percent of 131 is 98 , the highest cylinder reading is 131. Therefore, cylinder No. 3 being 60 which is less than 75% of cylinder No. 4 indicates an improperly seated valve or worn or broken piston rings.
3. If two adjacent cylinders indicate low compression pressures and squirting oil on the pistons does not increase the compression, the cause may be a cylinder head gasket leak between the cylinders. Engine oil and/or coolant in the cylinders could result from this problem.
30x clearer for me to understand, but if my car was tested already for this wouldn't i just be doing the same thing again? i don't know if they tried fixing the car or if they just tested it.
Old Jul 23, 2010 | 11:48 AM
  #28
The indicated compression pressures are considered normal if the lowest reading cylinder is at least 75% of the highest.
fixed. Other way didn't make sense
Old Jul 23, 2010 | 11:56 AM
  #29
when they do the compression test the bad cyl they need to put a little oil in the spark plug hole then compression test it again, its called a leak down test. if you have bad rings the compression will rise. if it stays the same then its a valve
Old Jul 23, 2010 | 08:56 PM
  #30
JayVee's Avatar
Well I really appreciate the help you guys have given me, but my mom's friend is a mechanic and he actually troubleshooted the car.
The only problem was the bad cylinder needed a valve adjustment, and he did it pretty cheap.
nonetheless, problem solved. !
thanks guys!
rcgtsport
Jul 12, 2011 04:51 PM
siguy2000
Apr 23, 2008 05:15 PM
foress_89
Oct 8, 2007 09:04 PM
larsenracing
Mar 3, 2006 07:18 PM
nachoman
May 23, 2005 02:37 PM
