Low idle with AC on and engine power changes
Old Sep 3, 2011 | 06:56 PM
aundreas83's Avatar
Default Low idle with AC on and engine power changes
I have a 97 Honda civic LX with d16y7 engine. While I am driving I noticed the power cutting in and out and the rpm will change slightly as well, probably about 1/4 increase and decrease. When I come to a stop and idle I notice a low idle and the motor will rev up to about 1200 rpm then drop back down to about 300 rpm and continue to rev up and down within about 20 -30 seconds. So I turn the AC off and the problem goes away and runs perfect but as soon as i turn the AC back on it hesitates at take off then catches up quickly, then the entire time I gain and loose power even while cruising without accelerating. Would low freon cause this issue? What should I do? Thanks for any help.
*BTW new spark plugs and wires, compression is perfect across all cylinders. Ignition timing hasn't been fine tuned and might be off...
Old Sep 4, 2011 | 05:11 AM
Check that the condenser fan works. It should be on at all times the compressor is engaged. Does the A/C cool OK at highway speed? "Low freon" won't cause this, but having too much will.
Old Sep 4, 2011 | 07:02 AM
aundreas83's Avatar
The condensor fan does work with ac on and yes it does cool but not very well if its hot outside.
Old Sep 4, 2011 | 07:06 AM
aundreas83's Avatar
I also checked the freon with a gauge from autozone on the low side it show a little low but Ive thought about taking it to get serviced because I dont trust the cheap little gauge.
Old Sep 5, 2011 | 02:43 PM
aundreas83's Avatar
Any more suggestions?
Old Sep 5, 2011 | 03:17 PM
You need the real gauges to see if it's an issue of too much high side pressure.
JBaris
Nov 22, 2010 03:56 PM
HutterCivic2007
Nov 7, 2010 11:56 AM
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
H22CIV
Sep 27, 2006 01:13 PM
