Lug studs
Old May 13, 2007 | 08:08 PM
imnotinyourroom's Avatar
Default Lug studs
About a week ago i took my car to the shop cause my tie rod snaped. After the guy fixed it i had a flat and when i went to change it, the lug nuts had been striped on so two of them broke off. So i just quit. after i got it towed home i broke off the other two and started to take them out like my dad said. but you cant just hammer them out if someone knows how to do this please tell me.
Old May 13, 2007 | 08:13 PM
ej6buddy's Avatar
Default RE: Lug studs
never changed them on a civic, but i believe they're welded in (at least tacked)
Old May 13, 2007 | 08:16 PM
Well you can get them out just a little with the hammer but the hub is to close to what ever is holding the hub on. if you can understand what i just said.
Old May 14, 2007 | 05:02 AM
cderalow's Avatar
obviously the guy at the shop who replaced your tie rod end, damaged them when taking the wheel off.
bring it back and make them fix it
otherwise, you need to remove the hub in order to replace the wheel studs
Old May 14, 2007 | 11:41 AM
windcalmer's Avatar
If you do it yourself, make sure that you have a c-clamp or a vise to press the new ones in with.
burnindesirez02
Sep 9, 2020 08:26 PM
CivvyCloud
Nov 18, 2008 05:36 AM
nutty_360
Feb 15, 2007 10:59 AM
Chimera02EX
Sep 11, 2005 08:41 AM
DZNUTTS
Jun 8, 2005 03:19 PM
