main relay, solder, dead battery - help?
Hi all. The main relay on my 93 Del Sol had some badly cracked solder joints. I resoldered it a few days ago and popped the switch back in, hoping it would fix a mysterious electrical problem I'd been having in the fall. I turned the key and only got a sad chiming and a faint whir from the starter, as though the battery is dead. Now, the battery probably *is* dead, because prior to this the car sat in the driveway for two months in the freezing cold (don't ask...).
But I'm worried I might have shorted out part of the relay. I don't think I did - I'm a decent solderer - but could this cause symptoms similar to a drained battery?
And here's the big question: if there *is* a short, and I try to jump start the car, could I do any lasting damage to the electrical system - or can I just trust my fuses?
Go ahead and jump start. The only thing I could see is having the relay shorted so the fuel pump runs all the time (which would take a really determined effort to do with just solder). That would drain the battery within a few hours but not immediately.
ktorres1120
Sep 4, 2013 08:07 PM
tony123
Oct 16, 2006 09:11 AM
ICONOMAT
Dec 13, 2004 10:44 PM
