98 civic ex issue
Old Feb 16, 2012 | 11:22 PM
coolkidd's Avatar
Default 98 civic ex issue
This morning my Honda was running a little rough. Sounded kinda raspy. The check engine light began to flash. Not sure what it could be. I was thinking maybe the cat or 02 sensor?? Any feedback would be great. Thanks.
Old Feb 17, 2012 | 01:15 AM
axis11's Avatar
Start by retrieving trouble codes.
Old Feb 17, 2012 | 05:49 AM
Flashing CELs which do not stay on afterwards from my experience are mis fires. Pull the codes. No one can guess.
Old Feb 17, 2012 | 10:19 AM
coolkidd's Avatar
Had the code read. P0302, misfire cylinder 2. Changed the plugs, old ones were kinda black but dry. Changed the distributor cap. Wires are less then a year old. Could it be maybe some water got into my fuel? Or a clogged injector?
Old Feb 17, 2012 | 10:48 AM
coolkidd's Avatar
I guess I should also point out a little history of the car. It has 209000 miles. Last October I had the head replaced, new gasket set, distributor cap and rotor, plugs, wires, timing belt, water pump, ignition coil, thermostat and changed the tranny fluid. At the time timing was right on and compression tested fine. Maybe that will help to narrow down what might be wrong. As I said in the last post I changed a few things last night and it hasn't thrown the CEL light yet.
Old Feb 19, 2012 | 06:12 PM
coolkidd's Avatar
Any ideas?
Old Feb 19, 2012 | 06:36 PM
If the only symptom now is a different sound, it could be an exhaust leak.
mudhenFUF
Jan 16, 2023 08:43 PM
DJ0628
Oct 23, 2005 08:26 PM
fletch71
Jul 20, 2005 07:25 PM
hondaholic9
Jun 14, 2004 02:13 PM
