Misfire Cylinder 2
Is compression the same cold and hot? With the engine hot, do all the rocker arms for #2 become slack after the engine has been turned by hand to a position where the valves should be closed?
Note that the valves typically lose clearance as the engine heats up. If the rocker arm is still touching a valve it will not fully close, the leakage causes loss of compression.
That's about all you can do without taking the head off.
jonsaidthat
Jul 1, 2010 05:48 PM
giwatcher
Dec 28, 2009 06:32 AM
longdrive352
Nov 2, 2009 05:07 PM
CodeMan
Apr 28, 2009 07:49 AM
jeevan chodu
Dec 31, 2006 03:43 PM
