Misreading Speedo
Old Apr 24, 2006 | 04:21 AM
AK47's Avatar
Default Misreading Speedo
Ok. I read the other posts about speedos but they didnt really help me.
I have a 1996 DX coupe and my Speedo is freakin nuts.
Its always reading higher than I am actually going,for instance :
30MPH(speedo) is actually 25MPH(radar)
50MPH is 42MPH.
80MPH is really in the area of 60-70MPH.
Anybody have any idea where I should start looking to fix this prob?
Old Apr 24, 2006 | 09:28 AM
ef4life's Avatar
Default RE: Misreading Speedo
there really isn't a way to fix it. you can get a new speedo. i moved the needle on my speedo on accident and it came out to be accurate.
Old Apr 24, 2006 | 01:18 PM
larsenracing's Avatar
I think you can pull the needle straight out and it will come out ever so gently the replace it back on the zero mph it takes much tallent and lots of time. its just easier running that little calculator in your head. but good luck when you figure it out let me know so i can fix mine im 10MPH off to. O one way to fix it would be to put a smaller diameter tire on it. Good luck though
Old Apr 26, 2006 | 04:19 PM
AK47's Avatar
Thats not what I wanted to hear...
Old Apr 26, 2006 | 08:22 PM
buddah_jenkins's Avatar
if you changed your wheel/tire size then that could be part or all of the problem. i went from 14" to 16" & my speedo changed about 3mph. if you're on stock wheels...then you'll probably have to replace the speedo.
iamurDJ
Apr 9, 2006 05:38 PM
Impreza WRX
12
Feb 23, 2006 07:26 PM
derekdunham
Nov 20, 2005 10:30 AM
derekdunham
Jul 25, 2005 10:39 AM
nigel_miguel
Jul 6, 2005 09:38 PM
