missing link problem
i just fitted the missing link part but i dont think i put it on correctly this is what i got with no instructions.
the missing link
one O ring
2 longer bolts
a piece of foam?
and some washers
there are 3 holes in the link one on the top( large hole with a ring around it)
one on the bottom (very small)
and a small one on the side?
i had no idea so i guessed i put the foam in the large hole, put the o ring in the groove around the large hole, then put the map sensor on the top and attached it to the original mounting place using the larger bolts.
the car does not error but also does not run properly
any ideas did i do it right
the missing link
one O ring
2 longer bolts
a piece of foam?
and some washers
