Mobil 1
Old Nov 26, 2006 | 09:27 PM
Cory's Avatar
Default Mobil 1
I've read some posts using the "Search" function, but any new input on using Mobil 1 in my '06 Civic? After a few oil changes every 3,000 miles using Castrol GTX 5W20 I just switched to Mobil 1 5W20. The engine seems to run a bit "tighter" if that makes sense and seems noticably smoother and more effortless cruising at about 80 mph. Just wondering if there's any objective backing to using synthetic over petroleum based engine oil. Thanks.
Old Nov 27, 2006 | 10:25 AM
luisynayan's Avatar
Default RE: Mobil 1
From what I've read from reviews, Mobil 1 has some of the best synthetics out there... + it lasts longer.
Old Nov 27, 2006 | 10:39 AM
ef4life's Avatar
Default RE: Mobil 1
i use mobil 1 in my jeep, but i never ran anything else in it so i don't know if it helps or not.
Old Nov 27, 2006 | 12:06 PM
gotboost?'s Avatar
Default RE: Mobil 1
Yea mobil Ive heard is the best but ive also heard Royal Purple is the best for performance in synthetics but I go with Mobil 1 5w in the cold conditons and 10w int he warmer conditions...
Old Dec 3, 2006 | 10:44 PM
wantacivicwagon's Avatar
Default RE: Mobil 1
Ask this same question on www.bobistheoilguy.com
Old Dec 3, 2006 | 10:46 PM
gin0o0o's Avatar
Default RE: Mobil 1
yup switched over to mobil1 synthetic on my part
Old Dec 3, 2006 | 10:49 PM
riceburner700's Avatar
Default RE: Mobil 1
i ran royal purple for an oil change and then switched to mobil one and the mobil is way better in my opinion and cheaper
Old Jun 29, 2007 | 07:26 AM
bpapa's Avatar
Member
Default RE: Mobil 1
Ya, I ran royal for a few changes in my old 4runner and it seemed to make no difference vs. castrol syntec (which I've recently learned is not all that great...). It seemed like the price of the royal purple was its most noticable difference. (although I found it on sale cheaper than syntec once in a while)
Old Jun 29, 2007 | 07:41 AM
06coupe's Avatar
Default RE: Mobil 1
if you are changing your oil at 3000 miles in an 06 you are wasting a lot of money on oil, you should be following the maintainance minder on the dash which will tell you when to change the oil.
WILMER007
May 4, 2016 08:10 AM
natetrain1980
Jun 26, 2011 12:39 PM
regor
May 26, 2008 05:04 AM
Marty
Mar 6, 2006 06:48 AM
Marty
Feb 15, 2006 02:35 PM
