my check engine light codes... help please!!
Old Jan 18, 2006 | 07:37 PM
emericanidol's Avatar
Default my check engine light codes... help please!!
alright well i just checked what codes my check engine light was putting out and its putting out; (45) "system is too rich" or "system is too poor," (73) "cylinder no.3 misfire", and (74) "cylinder no.4 misfire".. im kind of new to fixing my car, so can someone please tell what i should do to fix these things. thanks any info will be appreciated...
Old Jan 18, 2006 | 08:41 PM
AgentofDarkness's Avatar
Default RE: my check engine light codes... help please!!
What is the year, trim (EX,LX,DX,SI), and the engine of your car?
Old Jan 18, 2006 | 09:12 PM
a 1997 HX 1.6L vtec-e
Old Jan 18, 2006 | 09:24 PM
Is your Civic from the U.S. or another country. A 1997 Civic should have an OBDII code, which goes something liek P0....
Old Jan 18, 2006 | 10:21 PM
yeah its U.S. so what do i need to do to fix the problems for the codes that were being put out?
Old Jan 18, 2006 | 10:34 PM
i don't know how you pulled the code, but the only way im familiar with is using a scan tool. OBDII has a standardized set of codes, so if you get the OBDII code then i might be able to help. Autozone or another store like it can pull the code if you have a check engine light.
Old Jan 18, 2006 | 10:51 PM
oooh yeah i got them, i got the codes by jumping the service check connector and counting the check engine light blinks, then looked these codes up... P0171 or P0172, P0303, and P0304.
Old Jan 19, 2006 | 12:30 PM
I looked up the codes on a website
P0171: It could be a vacuum leak. The code is that the the O2 sensor is detecting that your cylinders are running lean.
P0172: Also vacuum leak or fuel pressure problem. This code is that the O2 sensor is detecting the cylinders are running rich.
These two codes are the opposite, which doesn't make sense. Im gonna have to think about this one a little.
The last two codes (P0303 and P0304) are saying that both cylinders 3 and 4 are misfiring.
The engine usually shakes when there is a misfire. Lemme think about the problem a little, maybe i can think of wat the problem is. Or maybe someone else can help.
Old Jan 19, 2006 | 12:47 PM
mxs's Avatar
mxs
Check this out...
https://www.hondacivicforum.com/m_66...e/tm.htm#66613
DanoATX
Sep 17, 2010 09:49 AM
towelie
Aug 30, 2010 05:08 PM
that_guy5
Mar 16, 2007 07:18 PM
Methu969
Jan 22, 2007 01:13 PM
mobbology
Nov 29, 2006 05:37 PM
