is my theory right?
Old Feb 2, 2007 | 12:42 AM
98civex's Avatar
Default is my theory right?
hi guys i know there are other threads about the speedometer issue but i felt startin this would get right to my question. ok so my speedometer randomly has been dropping to zero and springin back up to the current speed. to see if it was the speed sensor i turned on cruise control when the needle had been droppin pretty consistantly. the idea was that if the needle dropped and the culprit is the speed sensor the cruise control should turn off (since cc is linked to the speed sensor in some way if i'm not mistaken) because it'd see the car was technically stopped (0 mph) and if the cc stayed on it had to be the speedometer itself. well it dropped few times and cc remained on and workin perfectly. so does this diagnosis make sense and i know to change the speedometer or am i makin things up? heh
Old Feb 2, 2007 | 02:09 AM
Djohnsto's Avatar
Default RE: is my theory right?
I think you need a new speedo cable. My sisters old mercury use to do it and they said it was the speedometer cable. I'm not positive if it is the same thing for Hondas tho but my guess it would be
Old Feb 2, 2007 | 06:34 AM
i'd say the speedo is the problem, i had the same thing happen to my 92 hatch i just changed speedo's and now it works fine
Old Feb 2, 2007 | 08:12 AM
drbyers's Avatar
new speedo needed, aye-aye captain!!1
faulty speedos on older model civics are a common problem. it used to happen on my old 93 EG hatch.
you're gonna have to replace it eventually, so start saving some jack.
Old Feb 2, 2007 | 08:17 AM
98civex's Avatar
so does my diagnosis make sense?[sm=idontcare.gif]
if i change the speedo can i just swap it and the milege out, or does an entire new cluster have to go in?
Old Feb 2, 2007 | 08:21 AM
drbyers's Avatar
go with whatever's cheaper.
hell, you may even be able to find a used cluster online like my brother did.
Old Feb 2, 2007 | 08:36 AM
Red Hot Rider's Avatar
You can just swap in the speedo.
I'll have an extra one here in about a week, that you are welcome to. Dunno how many miles it'll have on it, and I don't know if it can be altered to read your true mileage on the car. But I'll ship it to ya if you just pay for the shipping.
JDMTHEORY_Rian
Apr 29, 2008 09:49 AM
Talon585
Jul 13, 2006 10:24 PM
bills99si
May 6, 2006 11:13 AM
mill$civic
Nov 11, 2005 07:32 PM
Street Sniper
Sep 6, 2005 09:56 PM
