Mystified- cant get front brake discs off...
Old Jun 10, 2012 | 12:13 PM
pippo's Avatar
Default Mystified- cant get front brake discs off...
people,
These rotors/discs will not just pop off, even after removing the caliper like one would expect . Whats the trick/secret?
Thanks!
Old Jun 10, 2012 | 12:17 PM
Did you take out the two Phillips screws in between the wheel studs? If they won't unscrew, just drill them out. You don't have to put them back, the lug nuts hold everything together. The small screws are there to keep the rotors from falling off on the assembly line.
Old Jun 10, 2012 | 12:56 PM
pippo's Avatar
Yes, MK, I took off the 2 philip screws- with an impact driver. Now, the rotors jigggle around, but wont come out - theres the caliper "frame' preventing that. Seems like they engineered the steering knockle around the rotors. Still perplexed.....
Thanks, MK!
Old Jun 10, 2012 | 12:57 PM
pippo's Avatar
You may be aware of the setup- if youre a tech/honda guy- but if not, let me know and I can post a picture....
Old Jun 10, 2012 | 01:27 PM
The caliper bracket (what you're calling the "frame") comes off. There are two large bolts on the back side (the side that faces the inside of the car).
Old Jun 10, 2012 | 02:49 PM
pippo's Avatar
Ohh, geez- never woulda guessed. Youre right- came off with a little oooomphhh. 17mm. Other than that, its now a breeze. Thanks very much, again, MK! have a good Sunday night!
Old Jun 11, 2012 | 12:27 PM
pippo's Avatar
MK, (or someone else), do you know the torque to these bolts? especially the big 17mm ones that hold that caliper "bracket" than hugs the disc pads. Id apreciate any help, if possible.
Pip
Vexorg
Feb 17, 2012 07:02 AM
kev2809
Aug 18, 2008 11:26 AM
Asster
Mar 25, 2008 10:44 AM
red2000Si
Feb 11, 2007 01:06 PM
thebadgator87
Jan 11, 2007 09:52 PM
