need help idle problem
hey. i have a 95 civic d16z6. heres my problem the car revs up and down constantly to lets say 2500. replaced iacv tps fast idle valve new throttle body NO vacuum leaks.....i need help.
hey thanks for your reply i appreciate your help. no there is not cel i bled the system and little tiny bubble were coming out but nothing to big. i bled so much that i needed to refil it. here is another thing when you hit the gas it jerks and when you let off the gas it jerks too. so i was thinking is there a shortage in the tps wire?
If the TPS is fine, then refocus on the IACV and Fast idle Valve. Is the port for the Fast Idle Valve in the throttle body still pulling air when the engine is warm? Check by putting your finger over it.
