need help idle problem
Old Dec 8, 2008 | 06:51 PM
mtchu736's Avatar
this is the crazy part when i put my hand over the throttle body the car DOES NOT choke out. it barely even drops rpms....but there is no air being sucked in from anywhere! i checked every hose.
Old Dec 8, 2008 | 06:53 PM
StifflersMom's Avatar
Cat Fuсker
you have a vac leak. Now go look for it.
Old Dec 8, 2008 | 06:54 PM
mtchu736's Avatar
this all happened after i sprayed tb cleaner. would tb cleaner cause a vac leak
Old Dec 8, 2008 | 06:56 PM
Your throttle body gasket is likely leaking. You need a new gasket and the bolts must be properly torqued.
Cat Fuсker
where did you spray it?
Old Dec 8, 2008 | 06:57 PM
Damn, you are smart!
Old Dec 8, 2008 | 06:58 PM
Cat Fuсker
I iz, there ain't a doubt in anyonez mind that I iz.
mtchu736's Avatar
i sprayed it into the throttle body and intake manifold. ron i hope thats not sarcasm haha
Old Dec 8, 2008 | 07:00 PM
Cat Fuсker
you really shouldn't have sprayed it inside the TB...you're supposed to lightly spray the tb there it mates to the IM and teh vac lines and see if the idle changes.
Cat Fuсker
and hook the intake back on, don't run it without a filter.
