need help idle problem
You have to know Gene. He's actually a good guy, but he won't admit it.
it IS a vac leak. Has to be. now the problem could lie in that you removed the hoses...some of them have check valves (brake booster). Also you might not have hooked everything back up correctly.
1. start the car
2. observe the idle play
3. spray carb cleaner on TB and hoses
4. observe idle either change or not change
5. try to choke the car at the TB again.
6. report back.
If all the vacuum hoses are connected to the intake manifold (brake booster, PCV, cruise control, etc.), then I think you may have a leak from the throttle body gasket.
What happens if you spray some carb cleaner around the gasket as you are choking the throttle body?
