NEED HELP PLEASE !!!
Old Jun 15, 2007 | 07:34 AM
spitnhard79's Avatar
Default NEED HELP PLEASE !!!
Ok i have a 1995 Honda Civic with 1.5 16valve engine and auto tranny ...
Car runs great , except when i go over 50+ miles distanceon the highway , all of a suden the MPH gauge goes crazy jumping up and down , then it stops for a minute and then comes back , and you can feel the torque covertor acting funny ,and the mileage stops moving .. My first thought was speed sensor ?? but wouldnt that give a check engine light ??? No check engine light hascome on yet ever .. 115K miles
im truly stumped and i am driving 1400 miles each way next month , so i figured i should get started now ..... ANYONE have a CLUE ???
Old Jun 15, 2007 | 07:58 AM
Default RE: NEED HELP PLEASE !!!
Someone may have taken the bulb out of the check engine light. It should come on for a couple seconds when you turn the key on but don't crank the engine. It could also be a loose ground. Check the ground wires on the thermostat housing. The speed sensor is kind of expensive to just replace without confirming it dead first.
Old Jun 15, 2007 | 12:28 PM
Nope Check Engine Light works when key is turned forward , so that is not it, any other ideas ????
What ever it is , it only screws up 50 or more miles down the road ....
Could it be in the Tranny ???
Old Jun 15, 2007 | 01:18 PM
my94civic's Avatar
does it just start working again after a bit more driving, or does it return to normal after you havent driven the car for a while?
Old Jun 15, 2007 | 09:13 PM
I dont really have a answer for that , it has done it the last 2 times i went over 50+ miles ....
It runs fine everyday , even if i jump on the interstate and run 20-30 miles its ok but once i go 50-60 it starts up ...
I drive the car around the city with no problems ever !!! Its wierd
No one has had something similar ???
has anyone had a speed sensor go , on a model with out Cruise Control ???
if so how did it act ???
Old Jun 16, 2007 | 09:55 AM
Bump
Old Jun 16, 2007 | 01:01 PM
Old Jun 16, 2007 | 08:16 PM
come on civic guys help me out here !!!! PLEASE Local mechanic charges a arm and a leg 4 everything .....
Old Jun 19, 2007 | 06:39 AM
BUMP < anyone , someone , please help , im driving 4 hours this weekend .... what can i do ??
Old Jun 19, 2007 | 06:50 AM
mctwists's Avatar
take to a mechanic... or a honda dealer... what else can u do
