Need some help with malfunctioning corner lights
Alright i gotta 95 civic ex and my corners are screwin up. My left corner stays lit up when the lights are on but doesnt blink when i turn my blinker on. My right corner does not light up when the lights are on but blinks when i hit the blinker. Its not a burnt out bulb cause i checked that so if you guys have any suggestions on how to fix this problem help me out please.
I would check and see if the wiring has been tampered with. Are you the original owner? Any mods done to the headlights and such? I have the same problem and when I looked at the bulb socket it was different than the side that worked and one of the wires was loose. I tried to get it to work again but to no avail. I ordered a new bulb holder and the headlight rear gasket was missing so I ordered one of those also. Hope this helps
Here is a link to an exploded view!!! That site is very helpful!!!
http://www.hondaautomotiveparts.com/...DLIGHT+%281%29
!!Here is a link to an exploded view!!! That site is very helpful!!!
im not the orignal owner. There are no modifications to the headlights that i know of but i did hook up my gauges to the corner light wiring so there might be something wrong there. But ill get a voltmeter and check my wiring and fuses. Do you know which fuse goes to my corners because the previous guy did smoethin with the fuse box layout?
burnindesirez02
Apr 11, 2012 10:56 AM
burnindesirez02
Jan 20, 2009 05:53 PM
RoundEyeRacing1904
Jan 1, 2006 10:20 PM
