neutral safety switch acting up - how to fix/replace? on 96 HX
Old Jul 20, 2006 | 11:40 AM
snosurfa7's Avatar
Default neutral safety switch acting up - how to fix/replace? on 96 HX
Ok, I finally (think) I figured out what was going on w/ starting my car...When I would crank it I would get all power but no start - no turning of the engine, not even a click from the starter, and I did hear the fuel pump engage. So I'd try again, and it'd start right up. Next time it did it, I tried it w/o pushing in the clutch again, and the next time w/ pushing in the clutch again - mashing it, almost. The latter worked, whereas the former didn't so...Battery/alt/connections/starter all tested ok as well.
So how do I fix/replace the neutral safety switch?
And where exactly is it located under that dash (pics would be of great help)?
96 HX thanks!
Old Jul 20, 2006 | 06:16 PM
gwl's Avatar
gwl
Default RE: neutral safety switch acting up - how to fix/replace? on 96 HX
It should be at the cluth pedal assy. Look straight up from the clutch pedal and you will see it.
Old Jul 24, 2006 | 06:23 PM
snosurfa7's Avatar
Thanks...but I still can't find it. I even have my Haynes manual and it shows this little bracket w/ 2 bolts - but you know how those Haynes pics are - not so bright. Maybe I can't get my head up to where it is too - it is a hard contortionist effort to get under that dash in the first place. If anyone can take a pic and post it that'd be great - Thanks!
Old Jul 25, 2006 | 10:13 AM
gwl's Avatar
gwl
I will try to post a pic when I get home.
Old Jul 26, 2006 | 02:08 PM
snosurfa7's Avatar
Thanks gwl, I'd appreciate that - I'll keep an eye out for it.
Old Jul 28, 2006 | 07:02 AM
gwl's Avatar
gwl
Here is a pic in a part breakdown.
[IMG]local://upfiles/9361/371F39AAE0AF41DF99F807FD5E81F2D9.jpg[/IMG]
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
ghostbusters101
Dec 15, 2010 07:32 PM
itsfliproduct
Oct 25, 2008 08:02 AM
speed_demon
Mar 9, 2007 08:38 AM
shellebelle
Oct 7, 2005 06:11 PM
