New pads and rotors to fix wheel wobble due to warped rotors. Still wobbling.
I've been doing my brakes for a long time, and usually whenever they get warped I'll take the rotors somewhere to be ground down on that lathe, or I'll just get new rotors if I'm in a hurry.
I was in a hurry a week ago when I did these, and after putting on new pads and new rotors, I'm still getting that warped rotor, wheel-shake when braking. Also feedback in the pedal.
Any idea why that might be? Every other time I've replaced the rotors it's normally smooth sailing. I just went out there and took the wheels off and double checked all the bolts to make sure nothing was loose, nothing was.
So anyway, here are symptoms:
1. Wheel wobble and bumpy feeling in the brake when braking, especially at highway speeds.
2. No wheel wobble or weird feeling unless I depress the brake pedal, so I'm 99% positive it's got something to do with the brakes.
Any ideas?
-Mark
Any ideas?
-Mark
If the brakes are dragging, they will overheat and warp. This can happen in the first few miles on a set of brand new rotors.
Also if you don't remove the anti-rust shipping coating from new rotors before installing, it will gum up the pads.
The new rotors could be faulty if they never overheated. Bad calipers won't cause shaking directly, but they can stick and drag leading to warping. Drive without using the brakes much then get out and check the wheel temperatures.
don't overlook that there may be rust/corrosion build-up on the hub face (or debris on the rotor mating face). If the rotor doesn't sit flush when you install it it's possible to warp rotors that way.
(although I would bow to mk, who knows a HECK of a lot about Hondas!)
Did you bleed the brakes after swapping in the new parts? Also, when was the last time you flushed your brake fluid?
It sounds to me like you might have gotten a bum set of rotors, it happens. I had it happen to me the last time I did the fronts on my WRX. Definitely an annoying situation!
Kvwlvw
Jan 2, 2014 08:07 AM
Clean_Civic_98
15
Aug 12, 2010 10:32 AM
