new pan gasket but still leaking
Old May 14, 2011 | 07:51 PM
brew52's Avatar
Default new pan gasket but still leaking
new felpro perma dry pan gasket installed but still leaking . Installed with no sealant as per instructions & torqued properley & leaking where pan meets front timing cover any ideas ?
Old May 14, 2011 | 09:18 PM
conceptualpolymer's Avatar
I would remove the cover and gasket before taking a good look at the metal sealing surfaces. Look for areas that are not flat or that have large scratches. If anything like this is found you may need to remove or "assist" with a sealant.
Old May 15, 2011 | 05:37 PM
david13's Avatar
The original build on almost every car and every surface today is silicon sealant. For that reason they don't leak.
Why they say no sealant is beyond me. It is a miracle product that means no leaks. Plain and simple. No mess in the driveway, no stains on the garage floor.
It's no secret, but it's the true cure for any leak.
dc
RonJ
Apr 28, 2011 11:56 AM
beagler
Dec 7, 2010 04:44 AM
Speed JUnkyz
Mar 15, 2010 03:34 PM
ic892003
20
Aug 21, 2008 03:40 PM
herpsunlimited
Jan 7, 2008 07:49 PM
