no brake lights
Old Apr 23, 2010 | 11:09 AM
nc989's Avatar
Default no brake lights
93 civic yesterday the right turn signal stopped working and still isnt working now today the brake lights are out even when you turn the lights on no brake lights what so ever or right turn signal. all the fuses are fine to my knowledge i took them out and there all good i have no clue what it could be now?
Old Apr 23, 2010 | 11:45 AM
Always when something doesn't light up, check the bulb first and go from there. If you find a bunch of blown bulbs the alternator may be overcharging so there is too much voltage. Check that power is reaching the brake light switch and also appears on the other side when you press the pedal. It is common for the wires in the back to break where they flex every time you open the hatch or trunk. Also the sockets get rusty and lose contact with the bulbs.
When you push the turn signal lever right, what happens? Anything? Does the light on the dash or either of the lights on the outside of the car come on?
Old Apr 23, 2010 | 02:40 PM
nc989's Avatar
no lights on the turn signal somtimes it makes a tick thats it. none of the bulbs are blown they worked for a second earlier then stopped again
Old Apr 24, 2010 | 07:39 AM
Press the 4 way blinker button, do all the bulbs blink? If so go to the next test--
Take the steering column cover off and unplug the 3 wire plug from the turn signal switch. Jump the green-orange to the green-blue (turn key on) and it should blink left. Then jump the green-orange to the green-yellow and it should blink right. If it blinks OK by bypassing the switch, the switch is bad.
Old Apr 24, 2010 | 08:51 AM
nc989's Avatar
alright so the brake lights still arent working. the bulbs arent blown the fuses are there not rusty what could be the cause?
Old Apr 24, 2010 | 09:06 AM
OK moving on to the brake lights you should check the switch on the brake pedal arm. Check that power is reaching it. One terminal would be live all the time and the other live only when the pedal is pressed.
gmanjase
Nov 6, 2013 10:33 PM
itzcorky
Sep 21, 2011 07:45 AM
Cosworth
Dec 15, 2008 05:35 AM
j2performance
Jan 15, 2008 01:48 PM
Stumasters
Jan 17, 2007 01:36 AM
