No power
before i took my head off only 3cylinders where running
i took the head off n put new valves n all that good stuff the process went GREAT
now i have all my cylinders running its jus the timings good rpms read good n evrything but
its not wanting to pick up speed n if u jus throttle it its just not lik if its not getting power
i figure maybe it could be the pulley cables on wrong it shouldnt be but maybe n my ecu was marking injector code i restarted it n the code went away but same problem still
if u could help in ne way it be great thanks much
The first thought that comes to mind is that the timing belt was installed one-tooth OFF from synchronizing the cam and crank at TDC1. Carefully recheck the mechanical timing. If the mechanical timing turns out to be fine, then next check the ignition timing with a timing gun.
yea i think the pulley cable was put on wrong when putting it back on the cam ima try that thanks another question on my 92 hatch automatic the ecu got wet i guess last weekend n my dad started it up n he fryd my ecu
i got another one matching codes po6 automatic the cars cranking n cranking but wont give go
Start by checking for blown fuses under the dash (e.g., fuses 18 and 24) and hood (e.g., fuse 31).
prodigyskate5
Jan 21, 2009 01:13 PM
XNXIXTXRXOX
Aug 22, 2008 10:11 AM
Kturner
Sep 25, 2006 08:38 AM
