No start! Fuel, spark, cranks, won't turn over.
hi all
i've got spark and fuel, but my car still won't start.
i tested spark on all 4 cylinders. spark plugs are getting wet with fuel. they were very black when i pulled them, so i wire brushed them and re-gapped them.
my oil light goes out after 3 or so cranks.
my oil level is good.
not throwing any codes either.
what could this be? faulty distributor?
You should check the timing and compression. Spark plugs black or wet suggests way too much gas, such as too much pressure from the regulator(*), or an injector stuck open. Is it the DPFI system?
(*) Also check the vacuum hose on the back of the regulator, it should be dry. If regulator is blown it will pour gas into the engine through that hose.
well i got it to turn over and run briefly.
we went to do the ignition timing, hooked up the timing light, and suddenly it won't start at all now! throwing code 15. blk/yel wire has power. soooo frustrating.
i think my coil is straight up dead.
DaCivicman
Jul 3, 2014 03:35 AM
DaCivicman
Jul 1, 2014 12:07 AM
Mecca8383
Mar 31, 2014 05:15 AM
joelmatt89
Jan 15, 2009 08:41 PM
ollie
May 6, 2005 10:18 PM
