Non starting 97 civic HX
All 3 sensors in the distributor should have nearly the same resistance and no faults to ground. Unless the HX is radically different from the other versions, all timing comes from the distributor. A bad CKF sensor on the crank would not prevent starting.
Understood. Initially it appeared as if the timing belt had skipped. The cam gear was reset to TDC along with the crank. Belt, tensioner, and water pump were replaced. Additionally, the distributor, cap, wires, and plugs are brand new. The voltage at the injectors is constant and not pulsing.
Does the ignition fire sparks? You probably won't see injector pulses with a meter. Unplug one injector and put a light bulb in the plug, see if the bulb flashes. If the timing belt has skipped you need to consider the possibility of valve damage and loss of compression.
new2honda
Aug 21, 2014 05:49 PM
giwatcher
Feb 14, 2009 09:14 AM
dmsteele92831
Jul 23, 2007 11:10 AM
totenkopf
May 31, 2007 03:36 PM
