O2 Sensor
no that wont work becasue they are reading two different things:
The only way to get past the 2nd o2 sensor's code is with a simulator or an o2 extension. If you removed the cat though, it'll still give you a CEL with the extnesion because although the o2 sensors in the right place, you dont have a cat so the catalytic converters efficiency is also going to read below par.
Primary o2 sensor is used by the ecu to tune a/f ratio. Secondary o2 sensor is to see if the catalytic converter is working properly.
So i found this one ebay, and read it all looks like it will work with hondas
Do you guys know of anywhere else to get one? or any othr styles, i don't quite like it how you have to adjust it even tho it looks like a cool feature.
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
Vox1
Oct 14, 2007 12:29 PM
00sithrottle
May 12, 2005 10:25 AM
