o2 Sensor..
Old Oct 28, 2009 | 02:47 PM
Outlawmusician's Avatar
Default o2 Sensor..
I took my car to get my state inspection and they told me that my o2 sensor is at fault(PO135) so he told me he could reset it and that I would have to drive 20 miles to correct it, my question is would resetting fix it or would I have to fork out the 100 bucks for a new sensor?
Someone else told me that changing the oil would help me pass but I changed it only 2000 miles ago.
Sorry if there is a thread already like this but thanks for any help.
Old Oct 28, 2009 | 02:55 PM
hamorhead's Avatar
what year and model and engine?
Old Oct 28, 2009 | 04:05 PM
If your CEL is staying lit while you drive and that's the only code you have, it's going to need a new sensor. You can try resetting but the light is probably going to come back on after a drive. Your car will not pass if the CEL is on for any reason. Also you can't reset and go right back for a test before the light comes back on, because a code will be set indicating it has been recently reset, so it won't pass because of that.
Old Oct 28, 2009 | 08:25 PM
its only 60$ at advance auto parts ive just bought one, and yes it will have to be changed if the cel is on for it.
Old Nov 1, 2009 | 09:13 AM
It's a 97 Civic Ex.
Well I replace the sensor before the cat converter took it back to get re-tested and it failed with the same codes...Po135 and P1509 which is the o2 sensor bank 1 sensor 1 and my IAC valve...sooo I can't buy a new sensor and a new IAC valve my question is can I clean the IACV to make it work and what can I do about the o2 sensor even after I put a new one in?
MY CEL light doesn't work either.
Oh is the d16y8 a "vtec"?
Old Nov 1, 2009 | 10:48 AM
yes clean the iacv, here is a link on the how to.
http://www.team-integra.net/sections...ArticleID=1174
and for the o2 put the one you took out back in and put the new one in the other o2 spot.
Old Nov 1, 2009 | 02:19 PM
Ok I'll clean it.
Why is there a downstream and upstream o2 sensor? wha'ts the difference
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
