O2 Sensor (A/F Sensor) Issues
Old Nov 7, 2010 | 11:34 AM
Token21's Avatar
Default O2 Sensor (A/F Sensor) Issues
I have a 97 honda civic EX, i replaced the O2 sensor before the cat with a universal O2 Sensor and the CEL went off for a few days then poped back on. When i went to go get it checked; it was the same code p0135. I have black soot on my bumper and im wondering if one or more of my injectors are shooting to much fuel and blowing my Sensor off. I have heard a cold air intake system can do something towards running your engine rich but that doesnt really make any sense to me. should i replace the o2 sensor with an OEM part? Or pull off my injectors?
Old Nov 7, 2010 | 02:12 PM
If fuse 15 is not blown, then triple check your wiring job. Did you solder your wire splices?
Old Nov 7, 2010 | 07:57 PM
Code 135 is the heater circuit, going to be a problem with the sensor, wiring, or fuse. Wrong A/F ratio due to bad injector will cause a different code.
justinlee0
Jul 26, 2010 08:39 PM
98 civic hx
May 12, 2008 06:02 PM
wazman
18
Jan 16, 2008 09:01 AM
ictoan
Sep 17, 2007 07:43 PM
stylincompact
May 31, 2006 07:24 AM
