obd0-obd1?
Old Apr 8, 2006 | 11:50 PM
b8teen's Avatar
Default RE: obd0-obd1?
you are the man! thank you very much. i found another one but its pricy. thanks alot.
mike
Old Apr 9, 2006 | 02:16 AM
nightrider46's Avatar
No problem, good luck
Old Apr 10, 2006 | 12:39 AM
b8teen's Avatar
one more question, i already did the mpfi swap on the car, do i need to reverse everything i did in order to hook this harness up correctly? because i saw some other wires off of the harness that looked like mpfi injector wires. so i dont know what to do when i hook everything up. thanks for all your help.
Old Apr 11, 2006 | 12:43 AM
i dont get wut your really tring to say
Old Apr 11, 2006 | 10:15 AM
Solid_Snake's Avatar
taken from the website:
"Requirements: All civic/crx models must either be a SI or HF or a MPFI(Multi Point Fuel Injection) converted car. DX and Standard models that are DPFI (Dual Point Fuel Injection) must be converted to MPFI for this conversion to work properly."
Old Apr 11, 2006 | 10:19 AM
i guess u have to change ur injectors or play around with your wiring (thats if u kno how to customize ur harness)
Old Apr 11, 2006 | 10:23 AM
If its a lot easier for u to just get the harness for that engine, then that would be ur best bet instead of tring to convert it yourself
Old Apr 11, 2006 | 10:27 AM
If you want to stay with the conversion then this might help you step by step
http://xenocron.com/install/OBD0-OBD1.htm
Old Apr 11, 2006 | 11:15 AM
ef4life's Avatar
the conversion isn't that hard. i bough my harness from www.boomslang.us and had no problems installing it it came with great directions. if wiring intimidates you, look to www.rywire.com they can build you a whole plug in harness from the b18 and the civic harnesses.
one1sickhb
Nov 14, 2006 09:30 PM
b16avtec
EG Swaps
Oct 26, 2006 05:25 PM
psychocivic
Mar 13, 2006 12:13 AM
smokingemcee
Jan 20, 2006 06:14 PM
smokingemcee
Aug 24, 2005 09:57 PM
