OBD2 to OBD1 conversion.
Old Mar 19, 2007 | 10:03 AM
FlipHKD720's Avatar
Default RE: OBD2 to OBD1 conversion.
Tony (Forty04) did an OBD2 - OBD1 conversion in a 99, and like he said, seriously, the dizzy isn't necesarry. I've never heard of that and theres quite a few people on here that have turboed/converted to OBD1
Old Mar 19, 2007 | 10:10 AM
Fiasco's Avatar
pretty sure flip is correct. Im planning on doing this and didnt think the dizzy was neccesary
Old Mar 19, 2007 | 10:18 AM
ORIGINAL: cookie
thanks,well im doing 99 integra obd2 try put in to 93 civic si obd1.i have alternator and p28 ecu.da only thing it really get me is da distributor i have bd2 n obd1,can i switchda plug same color coding.but i dont know if same color coding going to ecu.
I dont think that p28 is the proper ECU for your application.
Old Mar 19, 2007 | 11:06 AM
FlipHKD720's Avatar
ORIGINAL: Forty04
ORIGINAL: cookie
if its got a basemap does it really matter Tony?
Old Mar 19, 2007 | 11:37 AM
yea
Old Mar 21, 2007 | 07:06 AM
cookie's Avatar
okay guys,can i use my clutch kitfrom my b16(cable tranny)n put in 2 ls motor(99 integra)[:-]
Old Mar 21, 2007 | 07:27 AM
FlipHKD720's Avatar
think thats a better suited question for Tranny/Differential
usually if its not in the same series (B series) it wont be interchangable
Old Mar 22, 2007 | 06:11 PM
dudes96's Avatar
you guys are probably right about the dizzy. i just know that mine needed changed becaus ei put a d16 z6 in a 96 ex. the dizzy was different from the d16z6 to y8 that is the only reason i said that. good luck on the swap sorry for the headache. it must have only been for the y8 to z6 swap. and a good place to pick up a conversion harness is www.xenocron.com this guy has a lot of good stuff
Old Mar 22, 2007 | 09:34 PM
FlipHKD720's Avatar
^ yea that may be OBD1 vs. OBD2 dizzys possibly. Thanks for the info though
Old Nov 26, 2007 | 04:40 PM
defjamon22z's Avatar
wut does dizzzy means? distributor? i dont know if my car had a d18y8 engine before but my car is a 96 LX so im assuming yeah? so my hardness is a d18y8 and my distributor is a d18y8 part obd2 so i gotta change it or... change the plug and match the color?
