odd electrical situation
Old May 22, 2005 | 12:15 PM
ufotruth's Avatar
Default odd electrical situation
Hi all. I have a stock '96 Honda Civic EX. I am having an electrical problem.
Problem:
Sometimes my power windows don't work. The same thing goes with my blower fan for the heater. Then there is the dash lights. When my headlights are not on, I can see the shift light that illuminates which gear I'm in. But sometimes, when I turn my headlights on, the the dash lights do not come on, and the shift light goes off. Now the cruise control light, blinkers, and low gas light, and the others always work. Then at other times, the dash illuminates just fine. And as a sidenote, all the gauges, speedometer, gas, oil, always work.
What I've tried:
I have checked all of my fuses. They are all good. I've used a continuity tester on all the plug wires leading out of the fuse box. They all check out good as well. I hotwired power straight into the power windows and the blower motor, and they checked out as working.
I'm not sure what else to do. If you have any ideas or suggestions, feel free to let me know. I have the whole dash off right now, and I'm willing to try anything.
Old May 22, 2005 | 12:23 PM
LEVIII's Avatar
Default RE: odd electrical situation
Check and clean your batt terminals also make sure the batt is grounded good and check all the engine brands
Old May 22, 2005 | 06:57 PM
sacicons's Avatar
engine brands? or grounds?
Old May 22, 2005 | 08:10 PM
Pete's Avatar
i had this problem before......the alternator was slowly dying out on me. If i were u i would do the following.
1st check the grounds like mentioned before....u can get all new grounds for about 20$..
2nd (if above failed).......get a new battery.....dont be cheap either ...get an Optima Yellowtop...(theyre like the hondas of batteries)$150
3rd (If ur still havin the problem).......get a new alternator.
if u do all that it should work......but like levi said.......do the free stuff first....make sure ur battery terminals are clean....and make sure the + terminal isnt loose......tighten it up.....check grounds.....ull be fine.
THE_FATTIE
Apr 3, 2010 06:13 AM
SI2000
May 2, 2006 06:17 PM
BallardCivic
Jan 6, 2006 11:21 PM
xe1002
Aug 29, 2005 05:38 PM
89CivicIN
Mar 21, 2005 09:11 PM
