oil leaking
Old Aug 14, 2007 | 11:00 AM
nik005's Avatar
Default oil leaking
so my 95 ex coupe is leaking oil and im 99% positive it is coming from the front main crankshaft seal and dripping down on to the crank pulley which is throwin it all over the engine so i was thinkin i might have to replace it which isnt so bad bout 5 or 6 hours but my dad suggested that i try puttin synthetic oil into it to see if it makes the seal swell up some and stop the leak is there any logic behind this i mean the engine was sittin round for like 2 years and the seal might have dried out so maybe this will work what u think
Old Aug 14, 2007 | 11:07 AM
Default RE: oil leaking
Synthetic oil isn't a bad idea in its own right but it is not likely to help. Replacing the seal is about the same effort as replacing the timing belt. You just go one step further and change the seal after you have the belt off. The belt of course has oil on it now which means you need to replace it anyway.
Old Aug 14, 2007 | 11:17 AM
nik005's Avatar
y would i have to replace it if it has oil on it
jaysdogjazz
13
Nov 21, 2015 09:07 PM
ic892003
20
Aug 21, 2008 03:40 PM
oilltd
Jun 10, 2008 04:06 PM
baker7598
Jun 21, 2005 11:47 PM
