Oil Pressure Light On
Old Aug 19, 2009 | 02:46 PM
medium_jay's Avatar
Default Oil Pressure Light On
Hey guys,
I've got a 2001 Honda Civic DX 5 spd. For the last month or so now the oil pressure light has been coming on at certain times. Usually just before an up-shift the light will illuminate, or when decelerating when coming to a stop, but then the light goes off once at a full stop. I'm a tech myself but this confuses me. The oil level seems to be fine, its not burning oil and no leaks anywhere to be found. I have parked beside a wall and listened to the engine and how it runs, but nothing seems wrong. The light tends to flicker a good amount, almost seems like a loose conection of some sort. This car has 140 000 kms. An oil change is due within the next few weeks so I'm thinking I'll start with that and see if it changes anything. Any other suggestions? I recently changed the timing belt, all other drive belts, and the water pump if that makes any difference. Anyone else have this problem? Thanks for your time guys.
Jeffrey Robertson
Old Aug 19, 2009 | 03:06 PM
danomatic93's Avatar
June 2010 ROTM
I would follow the oil temp wire from the sending unit on the block and look for any sign of cracks in the wire. The sending unit could be failing too, however sending units tend to fail completely and not intermittently. So, providing your engine is getting the proper pressure I would highly suspect the wire. Good luck!
Old Aug 19, 2009 | 06:40 PM
agreed^ check the wiring and if still dont find anything then replace the sending unit to see if the fixes the problem and problem still presests then it might be the oil pump going bad<-- last resort but start with everything else first.
MistaGlock
Jul 11, 2012 01:49 PM
budman007
Aug 22, 2010 03:07 PM
oilltd
Jun 10, 2008 04:06 PM
FlipHKD720
Apr 27, 2007 04:35 PM
