out with the auto in with the manual
yea i will miss the auto in traffic lol, but still be glad to be manual.
a little progress up-date, i have changed the brake pedal to a manual (smaller) one, installed the clutch pedal, master cylinder and lines ready to hook up to the new gearbox. i'm relying on the my car to get me around, so i need to think of everything to make time off road as quick as poss.
i have a vtec loom + ecu, so i will be changing the whole loom, less mess and it should make things easier for sure.
i must say i really appreciate all the good advise, keep it coming
he doesn't need the wiring harness but it would make things a lot easier. it'll just cost more. if you don't get the wiring harness you'll need an OBD2 to OBD1 conversion harness for the ECU end of the wiring, some custom wiring at the distributor, and you'll need to run your own VTEC wires.
not criticizing your comment, just adding to it so there's another option for him
i'm not sure if he meant D16Y7, or D15B7
because if for some reason he has a D16Y7 (idk maybe it was swapped in), he might be using the OBD2 wiring harness.
i'm going to guess that he has a D15B7 though since it would be the right engine if he has never had the engine swapped before. in that case, you would be right.
we need to get the facts straight.
i haven't started the conversion yet, but i have changed the brakes on the rear to disks. i'm having a bit of trouble gettin the brakes to work properly, although i've bled the system through all round and the fluid is running through, the brakes still seem to be a little spongy. would like to get this little issue sorted before i carry on with other things.
