Overeating..Fan..?
Old Nov 9, 2009 | 01:52 PM
DaOne's Avatar
Question Overeating..Fan..?
Ok so i jus replaced the old radiator with a new one. but now the fan doesnt seem to kick in when it stars getting hot...
i hooked up everything correctly im pretty sure. even checked the plug for the fan and made sure it wasnt dirty or anything.
any ideas wat could have made the radiator fan stop workin?
93Civic BTW
THANKS A LOT!!
Old Nov 9, 2009 | 04:05 PM
mathewkozak's Avatar
Check the coolant temp sensor. That regulates the fan on/off.
Old Nov 10, 2009 | 04:40 AM
Jump the sensor which is on the thermostat housing. (Unplug the sensor and put a jumper wire between the two pins in the plug on the harness.) The fan should now come on as soon as you turn the key on. If it doesn't, check the fuse, which is in the underhood fuse box. Also check that power is reaching the fan plug. If you have power at the fan but it doesn't run, motor is bad. You can remove the fan and connect it to a battery as another test of the motor.
If the fan does come on with the sensor plug jumped, test drive like that and make sure there's no overheating. Replace the sensor (Coolant Temperature Switch) if the only problem was it not turning the fan on. If it still overheats with the fan running all the time, there is another problem.
Old Nov 10, 2009 | 08:52 AM
DaOne's Avatar
Hey thanks!
yeah it was the fuse that went bad.
THANKS!
anivast999
May 14, 2011 06:15 PM
lillyrat
May 22, 2007 09:31 PM
Remmy
Apr 22, 2005 01:16 AM
foozball
Aug 12, 2004 08:18 PM
Lab Rat 21
Jul 21, 2004 08:31 PM
