Overheating:Coolant issue
Old Jan 13, 2006 | 02:12 PM
joey's Avatar
Default RE: Overheating:Coolant issue
had the engine been used previously? if so, whoever installed it for you probably didn't take the head off and change the gasket.
if you're losing coolant, check for leaks. if its not leaking, and coolant is circulating, then it's pretty much for sure your head gasket.
Old Jan 13, 2006 | 05:36 PM
mahmi's Avatar
I found out that its the water pump.... its leaking water/Coolant. Will I need to change the entire thing or just a hose? Any one know the price range?
Old Jan 13, 2006 | 08:03 PM
sacicons's Avatar
if you dont know how to change a timing belt, youre going to be paying for labor as well. expect to pay 200-700. you should do the timing belt at the same time, since they have about the same lifetime, and if the belt breaks, you will need a new head. and you have to take the belt off to do the water pump anyway.
mudhenFUF
Jan 16, 2023 08:43 PM
haynes83
Apr 6, 2012 09:13 AM
paak
14
Nov 19, 2011 02:24 PM
flinteastwood
May 10, 2011 02:43 AM
nicnac
Apr 25, 2007 07:35 AM
