Overheating mystery
Old Aug 5, 2019 | 07:20 PM
erndog's Avatar
Default Overheating mystery
My son's 2010 Civic DX-VP has a major issue with overheating during a long drive or anytime it is going faster than about 60. Runs about 2/3 to 3/4 of gauge normally, but tops out when under any load. Must implement mass heater-blow to cool down.
  • Originally, we discovered a seam leak on the radiator and replaced it and both hoses.
  • The fan blade had also disintegrated and we replaced the unit. Still overheated.
  • Replaced the thermostat and the lower ECT.
  • Replaced the ECM and had it reprogrammed/updated by Honda dealer.
  • All relays are good
  • Fans run appropriately
  • No water in oil
  • No condensation under filler cap
  • Coolant pressure test -extremely slow leak down-about one drop/2 or 3 minutes, external to engine
  • Runs well
  • Compression check
#1 188
#2 184
#3 180
#4 190
Old Aug 5, 2019 | 08:14 PM
StifflersMom's Avatar
Cat Fuсker
Let's start simple, has the rad cap/coolant reservoir cap (whichever one you have) been tested/replaced?
Old Aug 6, 2019 | 04:43 AM
erndog's Avatar
Yes it has.
Old Aug 11, 2019 | 04:49 PM
erndog's Avatar
Replaced water pump. Old one was fine. Next stop, head gasket.
Old Aug 30, 2019 | 10:29 AM
erndog's Avatar
So, I replaced the head gasket and got everything all buttoned up again. Engine started right up. Topped off fluids. Turned off engine. Checked tire pressures.
The "D" for Drive was blinking and the service engine light was on. Not knowing what the blinking D was all about, I read the codes and cleared them. I expected codes, due to all the disconnecting and reconnecting, so I didn't really pay much attention to them. One was the camshaft position sensor, and the other may have been the some, or maybe crankshaft sensor. Anyway, now the engine won't start at all. It cranks for a while and then one little putt and then cranks some more. D still blinks.
Any ideas??
Old Aug 31, 2019 | 10:29 AM
erndog's Avatar
Well, that little interruption has been solved. Found the camshaft position sensor disconnected. Plugged it in and the blinking went away, engine purrs, and car still runs hot. Not a warped head, because I just installed a fresh resurfaced pressure tested head.
Just put in a 170 thermostat to see if it makes any difference. Maybe the old one went bad?
Old Apr 16, 2020 | 12:35 PM
Scott Gordon's Avatar
Well did the Thermostat work? issue gone?
Old Apr 16, 2020 | 01:32 PM
erndog's Avatar
No, made no difference. Finally threw in the towel and sold it to someone who was willing to take a shot at it.
erndog
Aug 5, 2019 08:42 AM
Justinhelm1992
Apr 21, 2014 01:52 PM
mhillips
Aug 1, 2013 05:51 AM
bzackrie
Sep 27, 2011 04:15 AM
seatazzz
Sep 1, 2010 02:54 PM
