Overheating Problem
Old Dec 12, 2007 | 06:43 AM
mel0526's Avatar
Default RE: Overheating Problem
I had a friend that helped me last night and he said that my thermostat need to be replace finally. The leak is repair also...can the thermostat be replace without drainning all the coolant system? Where it's a good place to go in the US to repair a car?
Thanks you
Old Dec 12, 2007 | 07:03 AM
I don't think that draining all of the coolant from the system is necessary to replace the thermostat.
It would be best to ask friends in your local area to refer you to a good car mechanic or shop.
Old Dec 12, 2007 | 09:47 AM
ugh3012's Avatar
Some will leak when you pull the old one off then you can top it off after you replace it and I done that many time. Just place a cat box under where it will leak and you can see how much more you will need to top it off.
Old Dec 12, 2007 | 10:24 AM
timmytim's Avatar
Fix fans = fix over heating = fix coolant pressure = fix coolant leak. P
Old Dec 17, 2007 | 06:57 AM
mel0526's Avatar
Default Overheat...Head Gasket finish...
Thanks you for all your help...
I changed the thermostat yesterday on my car but it didn't change anything...and now I have a lot of smoke that go out from the muffler (and smell bad) and the oil have coolant in it. What are my option? I'm not a mechanic than I need to know if it have a easy fix (and how much it can cost)that will make my car go throught winter or if I'm better drive my bike...My civic is a 93, a lot rusted (because a lot of winter in Canada) and have 260200km (161680mile)
Thanks
Old Dec 17, 2007 | 08:30 AM
Default RE: Overheat...Head Gasket finish...
the head gasket is blown or may have a cracked head. $$$ my opinion just buy a engine and swap save ya alot of money and time. u can find an engine for 200-400$
Old Dec 17, 2007 | 10:49 PM
Civic Si 00's Avatar
Buried it already [sm=violent053.gif], Nah it will cost you some cash to fix it
phearly
May 15, 2007 04:38 AM
binrocha
Sep 6, 2006 10:31 PM
trebor_2005
May 19, 2006 01:40 AM
williamk9452
Apr 18, 2006 07:41 AM
Roadrunnr
12
May 18, 2005 12:27 AM
