P1259 code on 01 Honda Civic EX
Old Feb 18, 2006 | 01:57 PM
rkevin_t's Avatar
Default P1259 code on 01 Honda Civic EX
Getting a P1259 code pulled when my check engine light goes on. Dealer reset it and did some tests without it coming back. Said possibly a stuck spool valve.
2 days later and the check engine light is back on. Any suggestions with the P1259? Thanks.
Old Feb 18, 2006 | 02:04 PM
mxs's Avatar
mxs
Default RE: P1259 code on 01 Honda Civic EX
P1259 VTEC System Malfunction?
has the car been running okay? change anything recently?
Old Feb 18, 2006 | 02:10 PM
rkevin_t's Avatar
Running great and I have no previous problems. Went on a business trip and couple days after I got back I get the check engine light. have seen posts where the car was running low on oil but I checked the level and it was at the second mark as it should be. Like I said the dealer mentioned a stuck spool valve as a possibility.
There is no mods to the engine, all stock.
Old Mar 11, 2014 | 02:09 PM
markb540's Avatar
Default I'm Having the Same Issue
My '01 Civic EX with 246K miles has the P1259 code as well. I have done no troubleshooting at this point. I am looking for information to get started on that would add to the solution of this original thread which will probably assist in the solution of my issue as well.
The car is running well and I have a seemingly unrelated code of P0420 ongoing.
Old Mar 11, 2014 | 06:37 PM
itburnswhenIP's Avatar
the P1259 code could be from a dirty clogged vtec solenoid follow the cleaning DIY here DIY: forgotten tune-up mods - Honda Civic Forum
as for the p0420 that is from a faulty oxygen sensor or cat.
Old Mar 13, 2014 | 08:21 AM
markb540's Avatar
Thank you for the help on this. I checked with a friend and learned that the VTEC operates on oil pressure. I amaware that many know this and I'm learning more all the time. He suggested to change my oil. I did. Cleared the code and it has not returned. Not sure this may help your issue. At any rate, I found this info helpful.
Damname
Jan 24, 2014 05:58 PM
Gunner1130
Jan 21, 2010 12:17 PM
Thefbomb13
Sep 28, 2007 01:08 PM
Jase
Jun 19, 2007 01:26 PM
lesley257
Apr 11, 2007 03:13 PM
