Passenger Door Sensor Issue
Old Mar 28, 2008 | 04:52 AM
ViKz's Avatar
Default Passenger Door Sensor Issue
I have a '98 civic and my door light seems to stay on even though all the doors are closed properly. This is really annoying as I have an alarm and because the alarm has been activated and the light inside the car stays on because it thinks that a door is still open, the alarm keeps going off constantly.
As a temporary fix, i have put a little bit of tissue on the door sensor so that the car thinks the door is closed.
Does anyone have any ideas on what this problem is, and how to fix it?
I've been told that this is apparently a common problem with civics of this age?
Any suggestions will be greatly appreciated!!
Thanks
Old Mar 28, 2008 | 11:59 AM
bakertime's Avatar
Default RE: Passenger Door Sensor Issue
Try seeing if the bracket on the jamb is loose, that happened to me.
Old Mar 28, 2008 | 12:45 PM
ViKz's Avatar
thanks for your reply
sorry, buti've never checked the bracket on the jamb...how do i go about doing that? Did this resolve the problem for you?
Old Mar 28, 2008 | 02:44 PM
ORIGINAL: ViKz
sorry, but i've never checked the bracket on the jamb...how do i go about doing that? Did this resolve the problem for you?
Open your door and look at the bottom rear jam area. You should see a black rubber cover that protrudes slightly outward. Behind that rubber cover is the door switch. Remove the rubber cover and inspect the switch. It may help to compare it to the good switch in the opposite door.
Old Mar 28, 2008 | 03:10 PM
ViKz's Avatar
thank u so much, i will try that tomorrow and let you know if that has made a difference
mudhenFUF
Jan 16, 2023 08:43 PM
ashu
Aug 8, 2010 08:52 AM
jnkcivic
May 24, 2007 07:30 PM
Faithbleed
Oct 18, 2006 01:30 AM
jonyg98civicex
Aug 17, 2006 12:45 AM
